Sublimation Ink Types
The sublimation printer will only come with the inks that you decide to use. There are Three types of ink:
Chromablast is for white cotton fabrics only.
Sublijet ink is for white poly coated substrates (100% Polyester fabric, Urethane coated Mug Blanks, Mouse pads, etc.)
EasySubli Ink is similar to the Subliject, but can also be used on the SISER EasySubli Heat Transfer Vinyl, allowing for broader uses of textile graphic design.
You cannot swap between inks. Once you load one style of ink into the printer, you must only use that brand and type of ink.
