We do not provide direct cutting support from design programs such as Corel Draw, Adobe Illustrator, Photoshop, or InkScape. You can import files into your cutting program by using the Import command under the File menu.
Sure Cuts a Lot 3 Pro, and SignCut have plug-ins for their software that allows you to send directly from your design program to the cutting program. We do not provide direct support for the plug-ins, and you have to download them directly from the software developer's webpage. You can also checkout the USCutter forums for further information as many of our customer's will provide graphic design and unsupported setup guides on the forum.
