Multi-cut feature in Sure Cuts a Lot 3 Pro
Where is this feature in the program: Click on the scissors icon. On the initial Cut Settings window that pops up, you should see the multi-cut feature and can set to the number of times that the cutter will cut over in the same spot. As an example, if you cut out a 1 by 1 inch square and set the Multi-cut function to 3, it will cut over that square 3 times. This feature is primarily intended to help cut through thicker or denser materials using a 60 degree blade.
Please note, however, that when cutting the same design multiple times, good material tracking is very important, as any variation will result in unclean cuts.
