Adding Weeding Boxes in Sure Cuts A Lot 3 Pro
With your object selected, go to the Object in the top menu, then select the Weeding feature. Weeding is the process of removing the excess vinyl from in between shapes, inside of shapes (like the center of 'A's and 'D's) and around their respective edges. This feature will add a weeding border around the selected shapes with a specified Border Offset.You can also add horizontal and vertical weeding lines by choosing one the following weeding line types and then clicking within the weeding border to add the line. Add lines from the border to the outside edge of the shape Add lines within the filled area of the shape Add lines around the shape and in any holes within the shape Add a line within the specified area to remove a weeding line, click and drag the line outside of the weeding border. Clicking the Reset button will remove all weeding lines you have added.
