Sure Cuts a Lot 4 Pro - Locating Serial Number and Download Link
Created by Tom L, Modified on Mon, Jun 17, 2024 at 11:55 AM by Greg H
While Sure Cuts a Lot 3 Pro came with a physical disc that had a serial number on the back, some Sure Cuts a Lot 4 Pro serial numbers are obtained online using a redemption code.
  1. Locate the redemption card that came with your order.  It is roughly the size of a large gift card.
  2. Locate and remove the silver scratch off section on the card.
  3. The code will look something like "SCAP4-xxxxxxxxx", with the x's being numbers. Please verify that the entire code is showing and proceed to step 4.
  4. Go to the Craft Edge Redeem Code website,  or http://www.craftedge.com/redeem/scal4pro/
  5. Enter in a First and Last Name into the Name box
  6. Enter in an email address. Please Note: This email will be the one that is used to reclaim your software should you misplace the PSN, please be sure to use one that is reliable.
  7. Enter the code on the card from Step 3 into the Redeem Code box so that it matches the format on the site.
  8. Hit Submit. If the information you entered is correct, the page will refresh and give you a 25 digit serial number as well as the links to download Sure Cuts a Lot 4 Pro for either Windows or MacOS. Select the version you need and begin download.
    Do not close the page yet. You will want to write down the serial number from this page as you cannot redeem the code again should you close the site.
    If you do happen to close the site before copying down the serial number, you will need to got to the Lost Serial Number page and use the email address you registered under to reclaim your PSN.
  9. Follow the rest of the onscreen steps to complete your installation of Sure Cuts a Lot 4 Pro and happy cutting!
