How to Install your Cutter Driver through VinylMaster
Modified on: 2019-04-08 07:39:33 -0700
When initially setting up your cutter on your computer, your computer will need to know how to find your cutter. To do so, you will need to Install your cutter onto your computer. The drivers for your cutter are included in your cutting software. Here are the steps for installing your driver through VinylMaster.
If this is your first time setting up your cutter in VinylMaster, click here.
If you came here from the How to Set up your Cutter in VinylMaster article, continue below!
In the Vinyl Spooler Connections Tab, click on the "+ Add" button.
Select your Maker. For the TITAN series cutter, the maker will be TITAN. For the MH, SC, and Laserpoint Series vinyl cutter, the maker will be USCutter.
Select your specific model and size of cutter.
Click "Install".
Congrats! You're done! If this is your first time setup, you can return to the previous article.
