How to Set up your Cutter in VinylMaster
Modified on: 2019-04-08 07:27:17 -0700
Once you have installed the software and launched it, you will find an icon that looks like a space shuttle on the top bar beneath the text menus.
Clicking on that will give you the choice to select the "Vinyl Spooler" - do this.
The Vinyl Spooler will open, it will look similar to this (except it won't have any jobs listed in the queue list on the left pane since you have not used the software yet).
Click the tab in the right pane labeled "connection"
(if you have not plugged your cutter in to the power and USB and plugged the USB into the computer and turned it on, now is a great time to do so)
Make sure the "Current Cutter" lists your cutter model (How To)
Make Sure that your Connection Method Port Type is Correct based on your cutter model:
MH SeriesDirect USB Port
SC, SC2 SeriesDirect COM Port
Laserpoint SeriesDirect COM Port
TITAN Series
Direct USB Port
Note: Even if you have connected your SC, SC2, or Laserpoint Series cutter via USB, your connection will still show up in your computer as a Direct COM Port.
Click on "Detect", ignore the onscreen prompts.
Unplug the USB cable from the computer, it should move from step 1 to step 2 automatically.
Wait about 2-3 seconds and plug the USB cable right back in where you unplugged it from.
It should move from step 2 to step 3 and you should see a green check mark, indicating your cutter was detected and all is well.
If you don't get this screen, we'll need to speak with you directly to see what the issue might be, so please give us a call 1-425-481-3555. Support is ready to help, Monday - Friday, 7:30 AM - 11:30 AM, 12:30 PM - 4:00 PM PST. Please be sure to have access to your cutter and the connected computer when you call. When the technical support specialist answers your call, please give them your original order number for the cutter to expedite assistance. You can find your order number on your account with USCutter.com, Amazon, or eBay.
