Cutter not cutting at origin point that is sent on the cutter
Modified on: 2016-07-12 09:10:47 -0700
If the cutter is not cutting at where the origin point is set to in Vinyl Master Cut, there is a setting that can be changed in the software.
When you select File > Cut / Plot > Vinyl Spooler > Settings > Force position
Please make sure force position is unchecked and your cutter will cut out where the origin point is set on the cutter.
