MH and SC cutter main difference.
Modified on: 2016-06-16 07:06:17 -0700
The SC cutter has more down-force allowing it to cut heavier materials mainly. The SC is built a bit better than the MH and wold be more durable. The MH cutter just does not have the same down-force. For example the SC can cut dense 12 mil sandblast with a 60 degree blade at 200 pressure while the MH cutter needs 600 pressure or more with a 60 degree blade. Furthermore, the SC cutter is both Mac compatible and supports contour cutting while the MH is PC compatible only and does not have a laser for contour cutting.
