Paropy Inkjet Dark Classic Process
Modified on: 2016-06-16 08:55:07 -0700
After printing on the transfer paper for inkjet. Then peel away the backing slowly and carefully off the white backing. The heat press should be heated up already to 375 F. Then set pressure at medium pressure by adjusting the knob on the heat press. Pre-press shirt before pressing image for 5 seconds. Place image face up and cover it with the silicon sheets or sheets that came in the package with the transfer paper. Press the image for 25 seconds. Take off the silicon protective sheet and then remove shirt from heat press allowing it to cool on a flat surface. Paropy Inkjet Dark Process
