Multi-cut feature in Sure Cuts a Lot 3 Pro
Modified on: 2016-05-31 13:11:22 -0700
Where is this feature in the program: Click on the scissors icon There you should see the multi-cut feature and this should be set to the number of times that the cutter will cut over in the same spot. For example, if you cut out a 1 by 1 inch square, it will cut over that square 3 times. This feature helps cut through thicker or denser materials using a 60 degree blade.
