Double Cutting in Sure Cuts A Lot 3 Pro
Modified on: 2016-05-31 13:11:14 -0700
When your design appears to cut several times over in the same place it's usually caused by a simple import setting in Sure Cuts a Lot's trace feature. When you trace an image you need to ensure that your Mode (found just below the browse button on the trace page) is set to Monochrome. If it's set to Color your cutter will cut several layers of colors, often times black, grey and any other shades in your design.
