Getting extra cut lines through your design with Sure Cuts a Lot?
Modified on: 2016-05-31 12:01:23 -0700
If you are getting two horizontal lines through your cut job when using Sure Cuts a Lot, this is because the software hasn't been activated. It is running in trial mode and is putting a watermark through your work. You can activate the software by going to the Help menu and clicking "Activate". You'll be prompted to enter your name and the serial number for the software. The serial number can be found on the Sure Cuts a Lot package near the bar code. It is a 25 digit number with dashes in it. Make sure to enter the dashes as they are required. Then click OK. The software will thank you for activating and it will no longer cut the extra lines through your jobs.
