My USCutter SC is making a grinding sound
Modified on: 2017-11-15 09:18:23 -0800
Generally this can be caused during the shipping process but can be corrected. This continuous movement to the right is a result of the carriage metal arm in back not hitting the stop switch. Try the carriage correction video so that you can place the carriage back onto the track and also look behind the carriage and you will see that there is a small green box with a metal switch on it. The carriage has to align with this switch in order to stop the black box or carriage. Below you will find the SC carriage correction video as well as a .pdf guide for proper carriage alignment. These will explain some common errors you may encounter which can lead to poor cuts, and how to correct the issues when they occur. Click here to download the PDF guide
