Wrong Size Cuts / Cutting Size Calibration
Modified on: 2016-06-02 10:04:01 -0700
If your cuts are coming out any size other than exactly what you specified in your SignCut software then you are going to need to run a simple Cutting Size Calibration. You do this by clicking Cutter>Calibrate Cutter Size. Read the instructions and cut the 11.81" x 11.81" box, measure it, and then input the exact measurements of the box. This should correct the size of your cut, but you will want to cut the 11.81" x 11.81" box one more time just to make sure the correction worked.
